I have been using Lighting Analysis from Insight for a while, and in the last few days, I am having some strange results in the Illuminance Analysis.
It all started when I did the update of your latest version of Insight (Insight_Addin_2019_v3121) and I started to receive a “Warning Rooms: your project has no rooms…”, although I had rooms, and before doing the update the analyses were doing great (in other computers the analyses are running ok for the same model). I solved this (after some extensive research) deleting the result files from my computer.
Since then, I have been getting strange results when I proceed with Illuminance Analyses (the Solar Analysis runs normally, for example). What happens is the following:
- I have a model that used to work before, then I proceed with the analysis and I get a result like this:
All the rooms that have windows are extremely illuminated, everywhere, even in the corners. The scale goes beyond 10.000 lux.
However, when I run the exact same file on other computer/Revit, the analysis runs normally:
The settings, materials, climate data, location, etc, are all equal.
It happens on every model that I make. In my computer, I always receive an analysis extremely illuminated and on other computers, it runs normally.
Additionally, today, when I decided to execute a previous analysis that had “normal” results, the warning sign popped up again (like the image below) and now I can not run any analysis because this sign appears in every project that I have.
Thus, can you help me please to solve these issues? I have some urgency on this matter.
I appreciate your attention.
Kind regards,
Filipa Correia
