01:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings Sir/mam,
I've been trying to run some energy performance analysis for a building model I'm currently working on. I have run Heating/Cooling load analysis with no problem and when I try to run a Lighting analysis I get a message
"Failed to export document to SPD. SPD export failed. Check you have permissions."
I currently have a student subscribtion. I have seen on the mangament profile under "Product and services" a option of "
Insight - Lighting Analysis for Revit - student".
Should I have access to the Lighting analysis for Daylight analysis?
I'm running the Revit2018, since yesterday because I had some problems with Insight on the Revit2016 version. I uploaded a picture that shows the message and can be seen that I'm running a student verison of Revit.
Best regards,
Axel
