06:21 AM
I'm currently using Solar Analysis for my master thesis and I noticed when I export the results that the point x,y dose not correspond to the surface.
The yellow point are from the results and the blue ones are when I put the X,Y point from excel into Dynamo. My project/survey base point is set at 0,0,0.
As you can see the surface is 20x10 and its starts from (0,0) and the grid is approximately 4,5m but in the excel the grid is around 13m.
How can I solve this so the excel can show the exact point x,y on the surface?
Thanks!
