Solar Analysis shows only one color
Hi all,
I am trying to achieve the attached "REFERENCE" image for this project to understand how to use Insight 360.
However, instead of getting the different colors, I can only see all yellow...even the legend is all yellow. I have already set in the Color tab of the Analysis Display styles the different values and colors but it doesn't follow my settings...
Anything I did incorrectly? Please help. Thanks.
Jahzzy
krishnan.gowri
All roof area is on the same parallel plane with no shadowing or change in orientations - so it will have uniform solar exposure.  Hence the resulting single color for solar analysis results is correct.
Krishnan Gowri, Ph.D. FASHRAE, LEED AP
Principal Engineer
Generative Design Group
Hi Krishnan,
Thanks for responding but I wasn't talking about just the roof area. The first image was correctly done but it was done by my colleague who already left. I was trying to replicate it to understand how to use Insight 360. However, my result which is the 2nd image (yellow roof, yellow walls, all yellow legend values) is far from the first one. I also included in the snapshot the settings for my legend (which, apparently, it didn't follow).
Any ideas why?
Thanks again,
Jahzeel
mstein7484
Hi @Anonymous
Are you using Revit 2018 and are you running a non-English version of Revit? If so, please uninstall the Insight plugin and install the one attached to see if it solves the problem. We have noted some problems with Revit non-English having problems applying the Analysis Display correctly.
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Marjorie Stein
QA Analyst
Autodesk, Inc.
insight.support@autodesk.com
