"Failed to Generate Results. Please see Log File"
Hi, I've got Revit 2024 and the latest version of Insight addin installed but every time I run the analysis with different projects I recieve this error: "Failed to Generate Results. Please see Log File". I attach the only sign of problem which appear at he end of my log file:
8/7/2023 04:57:29 : ViewSchedule Name is Abaco dei pavimenti _InsightLighting
8/7/2023 04:57:29 : GetFloorScheduleFields
8/7/2023 04:57:29 : GetFloorScheduleFieldIds
8/7/2023 04:57:29 : Floor SchedulableFields: 352
8/7/2023 04:57:29 : **Inner exception in GetOrCreateDaylightingLevelSchedule
8/7/2023 04:57:29 : Messaggio:
The filter value is not valid for the field and filter type.
Parameter name: filter
8/7/2023 04:57:29 : DisplayPassFailResultsDF
8/7/2023 04:57:54 : Salva stato analisi in GenerateResults
8/7/2023 04:57:54 : - SetResultsInvalid: False
8/7/2023 04:57:54 : - SetScheduleOutdated False
8/7/2023 04:57:54 : SetRunResultsInMemory
8/7/2023 04:57:54 : SetLARExtStorageValue
8/7/2023 04:57:54 : SetRunInMemory
8/7/2023 04:57:54 : GetAllAnalysisRunInfosForDoc, 3
8/7/2023 04:57:54 : **Failed to Generate Results.
8/7/2023 04:57:55 :
8/7/2023 04:57:55 : ---- Start Main Process Exception ----
