Ports and Proxies for LAR and Rendering
Here is a question from a user:
I am having issue using rendering on the cloud and LAR at work. I have tried them from home and they worked, so I know that the account works fine. Is there any chance that firewall stops this action from taking place at my office? Could you give me any specification about firewalls to solve this issue?
Mohammad_Asl
The answer to this question:
Here is the list of proxies and ports that should be opened to allow unhindered use of Rendering and Lighting Analysis.
*.akamaiedge.net
*.amazonaws.com
*.autodesk.com
*.google-analytics.com
*.cloudfront.net
*.getsatisfaction.com
Firewalls should allow ports 80 and 443 to everything if possible.
Please let us know if you still have problems after using these settings.
Mohammad Asl
High Performance Building Design Researcher
Autodesk, Inc.
Insight360.support@autodesk.com
Specific domains we had to allow were:
api.autodesk.com
metering.autodesk.com
raas2.autodesk.com
rendering.cloud.autodesk.com
rendering.360.autodesk.com
Just in case your IT department doesn't want to allow access to the entire autodesk.com top-level domain for whatever reason.
