Announcements
Lighting setting dialog box doesn't show completely
edgar.rey
edgar.rey
Hello. I dowloaded the lighting analysis for Revit 2024, however, when I am trying to use it, the dialog box that you use to set all the parameter and choose the lighting analysis type doesn't show completely (see image below). The part of the box that doesn't show is the below one where the "ok" buton is. So, I can't complete any lighting analysis.
I wonder if someone has an help in this case. I appreciate.
edgar.rey
Hi All, I am using Revit 2025 and now the dialog box for daylighting and solar is showing perfect. I don't know why it couldn't work in R2024
