Hello. I dowloaded the lighting analysis for Revit 2024, however, when I am trying to use it, the dialog box that you use to set all the parameter and choose the lighting analysis type doesn't show completely (see image below). The part of the box that doesn't show is the below one where the "ok" buton is. So, I can't complete any lighting analysis.
I wonder if someone has an help in this case. I appreciate.
