LEED pilot credit - Daylight for Nordic Projects
Hello
Is it possible to use Insight for pilot credit calculations? The requirements are a bit different from the Daylight credit option 1, but would still require sDA simulation:  https://www.usgbc.org/node/12408067?return=/pilotcredits/Core-and-Shell/v4
It would be great if this calculation option could be added to the Insight selection menu. Alternatively could I manually change the inputs to calculate sDA 100/50% in addition to sDA 300/50%
scheerd
Hello.
It is indeed possible to modify the thresholds for sDA and Daylight Autonomy Preview.  To do that, right-click on the text in the Thresholds section of the Run New Analysis dialog to bring up the Thresholds dialog.
David
