I tried to do sDA & illuminance analysis with Insight 2018 for Education. I want to show how the surrounding buildings affects the daylight received by a building. Therefore, to include the neighbour buildings is important. I did that by placing them as mass and create mass floors, as I read somewhere that Insight will only take consideration those with floors or mass floors. Then, I run analysis for level 5, 15, 25, and 35 to see the difference.
After a lot of trials and errors, I see a pattern that makes me really confused.
So, if I run an analysis right after creating the energy model (without saving the Revit file), it will show a really low amount of light getting into the building (at first I was happy when seeing this result on level 5, because that means my assumptions that level 5 will be overshadowed by other buildings was correct). But then, level 35 shows similar result, which is really strange as my building is located near equator, in a very hot&humid tropical country. (I have checked the DNI and DHI showed in Insight settings for Illuminance analysis at a specific time & date, and it showed exactly the same numbers as weather data I downloaded from Autodesk Green Building Studio : around 700-900 in the afternoon all year, with clear sky for most of the time).
However, the next time I re-run daylight analysis (when the project had been saved) with the same energy model without changing anything, the sDA and illuminance for all of those floors showed totally different result. In the new result, all of them received a really high amount of daylight. Which seems to make sense for the higher levels (level 35), but not for level 5 and 15. This means all those masses surrounded the buildings were not even counted into the analysis.
Could anyone tell me what I did wrong? Any kind of help will be really appreciated.
Thanks.
