Error after error
Error after error
Error after error
Hi all, I've been trying to create a massing model to do solar, lighting and energy simulation analysis and I have been failing at this all week. Its a simple massing and I keep having the same errors:
Can someone please help me?
thanks.
stephanie.egger
Hi @Anonymous,
Can you tell me what version of Revit you are using and what Analysis Mode? The mode will be something like "Use Conceptual Masses" or "Use Conceptual Masses and Building Elements" in the Energy Settings.
-Stephanie
Stephanie Egger
Evangelist, Building Performance Analysis
blogs.autodesk.com/insight360
Hi Stephanie,
Yes so I am using Revit 2016 and "Conceptual Masses Only"
Thanks.
stephanie.egger
Could you try setting the Analysis Mode to "Use Conceptual Masses & Building Elements?" Also, feel free to share the model with me at [email protected] and I can take a look at it.
-Stephanie
Stephanie Egger
