Editing PV Panel type
Hi good evening to anyone reading this,
I am doing a project and I wanted to use the Insight 360 to do solar analysis on specific kinds of photovoltaic panels, does anyone know if I am able to set, edit or create the specific properties of the PV panels I want in either insight 360 or revit?
Thanks in advance!!!
stephanie.egger
Hi @Anonymous,
If you're doing the solar analysis within Revit, then yes, you can control a fair amount of settings. When you initiate the solar analysis plugin, select the gear/settings icon in the top right. From there, you'll be able to control the Study Settings, which include things like electricity cost, panel type, payback, etc.
Hope this helps.
-Stephanie
Stephanie Egger
Evangelist, Building Performance Analysis
blogs.autodesk.com/insight360
rick.vandelagemaat
So what I would like is to add a custom PV-panel type. For instance, we have a project with panels of 400Watt at the dimensions of 1.6 x 1.0m meter. Resulting in an efficiency of 25%. But I cant find how to add this custom % other than the three default ones.. Anyone who can help here?
Community Visitor
Community Visitor
Hey, did u find any way to do this?.
I'm searching for the same and couldn't figure out what to do.kindly share if figured out anything.
Thank you
