02:24 PM
I'm comparing data generated by the lighting analysis addin (see attached). There's something that I didn't expect. A room on the first level with a window on the north-east main facade has much more light that a seventh level one. Is it possible? Rooms have same shape ,same floor area, same glass properties and same shape and position of the window. Settings are ok and building site obstructions are included in the calculation.
It's strange because, a first level window sees less sky dome and has a lower radiation than a higher one (as it's shown in Vasari insolation mapping ran at the same hours -attached). Do you have any suggestions? Thank you,
Marika
