I am wondering if it is possible in Publisher to create hyperlinks that would link to another section? For example, in a parts book you would have a top level assembly and have links to jump to exploded views of the subassemblies.
Wade
Solved by Huan.Yu_Autodesk. Go to Solution.
Hello Wade,
Thank you for the question.
Could you please help me better understand your requirement?
Thank you!
-Huan
Huan,
1. What's your output format? Word, PDF, web/mobile, etc.?
Our output format would be PDF or web/mobile. PDF is still preferred because many of our machines are in areas where there is limited internet access.
2. It seems the hyperlinks work like bookmarks which can take you to the page you want within the document?
This is exactly what I am hoping for. To be able to have my top level assembly on the first page of the document and hyperlinks from there to other pages which would detail the subassemblies.
3. In Inventor Publisher, where do you want to put the hyperlinks? In the label/Callout?
In the callout preferably but I will probably have a BOM list on each page so if that was the only place to put a hyperlink I could make that work also.
