Hello.
Everytime i try to change the aspect ratio or anything at all in the "Publish Area setup", publisher crashes.
The company is running a Network license, but atm only 1 computer has the software.
Is there any hotfix for this, or should i just reinstall?
Windows 7 Professional 64bit
Inventor Publisher 2016
Intel Xeon E5-1607 @3.00 GHz
32gb ram
Any help is appreciated. Thank you.
Solved by roy.karnabi. Go to Solution.
Solved by na.miao. Go to Solution.
could you cplease heck your Region and Language setting ? if it's not English, please changing the format to English(United States) and try again.
Thank you
Hello.
I changed the language and region as stated in the link below. Worked wonders!
Thank you
