Hello.
I have the following problem using Inventor Publisher to generate 3D PDF files:
In Inventor, I placed a JPG- or PNG-Image onto an ipt part with the function "decal".
Then I exported it with "Export to dwf".
After this, I will open it with Inventor Publisher ("New" / "Import"). This will function sometimes, sometimes it will generate an error, too (50/50).
I don't know, what the reason is for this error. Is there a special bitmap format, Publisher needs?
Thank you.
