I have a model open in Publisher 2016 that has properties associated with each part from the parent model. These show up very well in the parts list feature, but when I export them to a 3D PDF or IPM, they do not display the properties of the part. The PDF doesn't display the properties in the object data pane under the model tree, and on the IPM viewer on Android, I click the part and it says it has no properties. The demo models that come with the phone app have the properties show up when the part is clicked.
I have had no luck finding a solution on the internet, please help! 2 screenshots attached.
Becky
Solved by bglass. Go to Solution.
Hello Becky,
At this point, part properties can not be exported and displayed in 3D PDF.
But if you publish to ipm and open the ipm in the mobile viewer, double click the part, you will be able to see the full part properties.
Please have a try. Thanks.
-Huan
I saw this a few days ago but never tried it. I will give it a shot now to see if it answers my questions below.
Solution/Summary:
Thank you Huan.
