I have an iLogic rule in a Part template file that sets the camera to the home position and the zoom to "fit all" when a new Part is created with the template. It works fine, but one annoying trait is the Part starts zoomed in on the rear (for some reason), and camera transitions are done as animations, which takes time and is unnecessary.
Is there any way to disable the camera transition animations, so the camera will instantly go to the right settings when the part is created?
I've attached a sample part with my code in it. To test, place the part in your Templates folder and create a new part using the template.
Using Inventor 2017.4.7
