Yield & Tensile Strength Changed Programmatically
Message 1 of 1
The Standard EN 10025 specifies various material strengths. In it the strength is de-rated as the thickness increases.
Is it possible to access the part’s/component’s material styles/properties to change these values accordingly using; iLogic, VBA &/or VB/VC++/VC# ?
I’m in the process of creating different Materials with the de-rated values, so changing the Material programmatically is also possible.
Which would be the easiest; iLogic, VBA or Visual Studio ?
Ideally, the coding would be contained within the part so the final process would happen without the user being aware.
Replies (0)
