Wrong tolerance value in VBA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have Issue to get the value of upper & lower tolerance when using "Limit Linear Tolerance"
- It show different value of upper/lower tolerance, even if we put same tolerance on different dimension
- It show wrong value if we put the value of upper/lower tolerance same as the model value.
Public Sub InchInspectionTable()
'SET A REFERENCE TO THE ACTIVATE DRAWING
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'SET REFERENCE TO THE ACTIVATE SHEET
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
'REMOVE EXISTING CUSTOM TABLE
If oSheet.CustomTables.Count > 0 Then
oSheet.CustomTables.Item(1).Delete
End If
'CREATE CUSTOM TABLE
Dim CustomTableTitle As String
CustomTableTitle = "INSPECTION DIMENSIONS" 'Set the Table title
Dim oTitles(1 To 4) As String 'set number of column
oTitles(1) = "INSPECTION LABEL" 'Set the table header 1
oTitles(2) = "DESIGNED DIMENSION" 'Set the table header 2
oTitles(3) = "UPPER TOLERANCE" 'Set the table header 3
oTitles(4) = "LOWER TOLERANCE" 'Set the table header 4
Dim InsP As Point2d
Set InsP = ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.125
oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.ColumnValueHorizontalJustification = kAlignTextCenter
Dim oGenDimCount As Integer
oGenDimCount = 0
Dim oDim As DrawingDimension
For Each oDim In oSheet.DrawingDimensions
If oDim.IsInspectionDimension Then
oGenDimCount = oGenDimCount + 1
End If
Next
Debug.Print "Inspection Dims Count = " + CStr(oGenDimCount)
Debug.Print "Drawing Dims Count = " + CStr(oSheet.DrawingDimensions.Count)
Dim oCustomTable As CustomTable
Set oInspDimTable = oSheet.CustomTables.Add(CustomTableTitle, InsP, 4, oGenDimCount, oTitles)
'SET THE VALUE OF THE TABLE
Dim oInspDimShape As InspectionDimensionShapeEnum
Dim oDesignedDimension As Variant
Dim oAngularDesignedDimension As Variant
Dim oInspDimNumber As String
Dim oInspDimRate As String
Dim i As Integer
Dim oCellInspDimNum As Cell
Dim oCellInspDim As Cell
Dim oCellInspUpTol As Cell
Dim oCellInspLowTol As Cell
Dim oColor As Color
Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
i = 1
If oDim.IsInspectionDimension And oDim.Type = 117474560 Or oDim.IsInspectionDimension And oDim.Type = 117475072 Or oDim.IsInspectionDimension And oDim.Type = 117475328 Then 'Linier Dimension
oDim.GetInspectionDimensionData oInspDimShape, oInspDimNumber, oInspDimRate
oDesignedDimension = ThisApplication.UnitsOfMeasure.GetStringFromValue(oDim.ModelValue, 11272)
Debug.Print oInspDimNumber
Debug.Print oDesignedDimension
Debug.Print "Tolerance type = " + CStr(oDim.Tolerance.ToleranceType)
Debug.Print "Tolerance Upper = " + CStr(oDim.Tolerance.Upper)
Debug.Print "Tolerance Lower = " + CStr(oDim.Tolerance.Lower)
Debug.Print "Tolerance Precision = " + CStr(oDim.TolerancePrecision)
Debug.Print ""
Set oCellInspDimNum = oInspDimTable.Rows.Item(i).Item("INSPECTION LABEL")
oCellInspDimNum.Value = oInspDimNumber
Set oCellInspDim = oInspDimTable.Rows.Item(i).Item("DESIGNED DIMENSION")
oCellInspDim.Value = oDesignedDimension
Select Case oDim.Tolerance.ToleranceType
Case kDeviationTolerance 'Deviation Tolerance
Set oCellInspUpTol = oInspDimTable.Rows.Item(i).Item("UPPER TOLERANCE")
oCellInspUpTol.Value = oDim.Tolerance.Upper / 2.54
Set oCellInspLowTol = oInspDimTable.Rows.Item(i).Item("LOWER TOLERANCE")
oCellInspLowTol.Value = oDim.Tolerance.Lower / 2.54
Case kLimitLinearTolerance 'Limit Linear Tolerance
End Select
i = i + 1
End If
Next
oInspDimTable.Sort "INSPECTION LABEL", True
Dim oRow As Row
For Each oRow In oInspDimTable.Rows
If oCellInspDimNum.Value <> oInspDimNumber Then
oRow.Delete
End If
Next
End Sub
