Message 1 of 1
WriteDataToStream not return IStream*
I can't get IStream pointer from AttributeSets.
Method WriteDataToFile work correctly.
Any Idea?
The native C++ code:
#include "stdafx.h"
#include <atlbase.h>
#import <RxInventor.tlb> \
rename_namespace("InventorNative") \
named_guids raw_dispinterfaces \
high_method_prefix("Method") \
rename("DeleteFile", "APIDeleteFile") \
rename("CopyFile", "APICopyFile") \
rename("MoveFile", "APIMoveFile") \
rename("SetEnvironmentVariable", "APISetEnvironmentVariable") \
rename("GetObject", "APIGetObject") \
exclude("_FILETIME", "IStream","ISequentialStream", \
"_LARGE_INTEGER", "_ULARGE_INTEGER", "tagSTATSTG", \
"IEnumUnknown","IPersistFile", "IPersist", "IPictureDisp")
using namespace InventorNative;
int main()
::CoInitialize(NULL);
HRESULT Result = NOERROR;
//Получение идентификатора Inventor
CLSID InvAppClsid;
Result = CLSIDFromProgID(L"Inventor.Application", &InvAppClsid);
//Получение смарт-указателя на IUnknown
CComPtr<IUnknown> pInvAppUnk;
Result = ::GetActiveObject(InvAppClsid, __nullptr, &pInvAppUnk);
CComPtr<Application> pInvApp;
//Запрос интерфейса Inventor
Result = pInvAppUnk->QueryInterface(__uuidof(Application), (void **)&pInvApp);
IStream *IS = nullptr;
_bstr_t xml("XML");
//Result = pInvApp->ActiveDocument->AttributeSets->DataIO->MethodWriteDataToFile(xml, L"D:\\1.txt");
Result = pInvApp->ActiveDocument->AttributeSets->DataIO->raw_WriteDataToStream(xml, reinterpret_cast<IUnknown**>( &IS));
::CoUninitialize();
return 0;
