Announcements
Write value to Excel table for validation
bbrumfield
bbrumfield
I am attempting to Randomly Generate a Drawing/Program number and add it to an excel spreadsheet, the hope is that my rule would generate the number, check the spreadsheet to make sure it doesn't exist then add the new number in the next available row, if the number does exist a message box prompts the user to generate a new number. Parts of the code work however I am failing measurably at writing to the spread sheet.
Thanks in advance
Brent
Walliguy
Hey Brent,
I have not had much luck dealing with Excel file either. But looking at the helper note, it looks like they have ".xls" not ".xlsx". I am sure it isn't that simple but throwing it out there.
Have a great one,
Chris
bbrumfield
Hi Chris,
Unfortunately, that wasn't the problem. I was able to finally write to Excel however I found that an insistence of Excel was left running when looking at task manager for each part number created and when pushing Parameters from an
assembly it slowed the process to a near stop. My thoughts for now, while a table with the newly created part numbers, description, user & date would be useful, the odds of repeating a 10-digit alpha number using both upper and lower case is pretty slim.
Brent
Brent
A.Acheson
Hi @bbrumfield
You should open and close the excel workbook before and after your operation is completed. The snippets for this are in the ilogic editor. If you need more control over the process then you can go the VB.NET excel dll route where you have the same power as VBA macro has.
Regards
Alan
bbrumfield
Update 12/30/2023
I was mistaken, excelApp.Visible = True or False and excelApp.Quit() make no difference the excel app continues to show in task manger. When pushing Parameters from an assembly or simply creating a new Part I end up with an instance showing in task manager for every part.
Hi A.Acheson,
I was able to kill the process by changing excel.app.visible to true. I'm still uncertain if the rule is actually checking to see if the part number exists. My thoughts are that I would trigger the rule on creation of a new part and create some variation of the Code to run on sheet metal parts only when pushing Parameters from an Assembly.
See Code Below (borrowed and modified from a snippet by Curtis Waguespack)
Sub Main()
Dim oDoc As Document = ThisDoc.Document
iLogicVb.UpdateWhenDone = True
Top:
oFile = "Path\File.xlsx"
'define Excel Application object
excelApp = CreateObject("Excel.Application")
'set Excel to run invisibly, change to true if you want to run it visibly
'suppress prompts (such as the compatibility checker)
excelApp.DisplayAlerts = False
Dim xCharArray() As Char = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ".ToCharArray
Dim xNoArray() As Char = "0123456789".ToCharArray
Dim xGenerator As System.Random = New System.Random()
Dim xStr As String = String.Empty
        While xStr.Length < 10
            If xGenerator.Next(0, 2) = 0 Then
                xStr &= xCharArray(xGenerator.Next(0, xCharArray.Length))
			Else
				xStr &= xNoArray(xGenerator.Next(0, xNoArray.Length))
        End While
		oValueToMatch = xStr
Dim oProName1 As String = "Default Table Part Number"
Dim oProName2 As String = "Default Table Description"
Dim oProSet As Inventor.PropertySet = ThisApplication.ActiveDocument.PropertySets.Item("User Defined Properties")
Dim oProp As Inventor.Property
Try
	oProp = oProSet(oProName1)
	oProp = oProSet(oProName2)
	Catch
	oProp = oProSet.Add("",oProName1)
	oProp = oProSet.Add("",oProName2)
End Try
If iProperties.Value("Custom","Default Table Part Number")= ""  Then
GoTo DescNeeded
Else If iProperties.Value("Custom","Default Table Part Number") > "" Then
GoTo UserTime
DescNeeded :
Desc = InputBox("Excel Table Description, ie: FT90FM, End Cap", "Enter Description Here")
iProperties.Value("Custom", "Default Table Part Number") = xStr
iProperties.Value("Custom", "Default Table Description") = Desc
oTime = Now.ToShortDateString
oUser = iProperties.Value("Custom", "ModifiedBy")
oDescriptionToMatch = Desc
iProperties.Value("Project","Part Number") = xStr
Goto StartPNAdd
UserTime :
oDescriptionToMatch = iProperties.Value("Custom", "Default Table Description")
StartPNAdd:
If Dir(oFile) <> "" Then
	'workbook exists, open it
	oWB = excelApp.Workbooks.Open(oFile)
	oWS = oWB.Worksheets(1)
Else
	Return 'exit rule
'Loop through the rows In column A
For iRow = 2 To oWS.UsedRange.Rows.Count
	'get value of the cell
	oCellValue = oWS.Cells(iRow, "A" ).Value
	If oCellValue = oValueToMatch  Then
		oWS.Cells(iRow, "A").Value = oCellValue + 1
		oFound = True
		Goto Top
	Else
		oFound = False
Next iRow
If oFound = False Then
	oWS.Cells(oWS.UsedRange.Rows.Count + 1, "A").Value = oValueToMatch
	oWS.Cells(oWS.UsedRange.Rows.Count, "B").Value = oDescriptionToMatch
	oWS.Cells(oWS.UsedRange.Rows.Count, "C").Value = oTime
	oWS.Cells(oWS.UsedRange.Rows.Count, "D").Value = oUser
'set all of the columns to autofit
excelApp.Columns.AutoFit
'save the file
oWB.Save
oDoc.Save
'close the workbook and the Excel Application
oWB.Close
excelApp.Quit()
'excelApp = Nothing
End Sub
Brent
bbrumfield
Revisiting my original Post:
I believe all issues are resolved including verifying that the new number isn't a duplicate and killing excel from running in processes.
Brent
