Write parameters into excel with Ilogic
Hi
I want Inventor to write a parameter into excel after I have updated the parameter "Rotation". I got the ilogic script to write to excel but it does not update the geometri between the loops. Have I missed a update command?
BR/Goran
SyntaxEditor Code Snippet
ExcelFile = "C:\_Vault Workspace\Designs\15\15-0161 Goran Optiska modeller\Penta prisma\Pentaprisma resultat.xlsx"
i=1
While (i<360)
    rotation = i
    column_vinkel = "A" & i+1
    column_Vinz = "B" & i+1
    column_Viny = "C" & i+1
    column_Voutx = "D" & i+1
    column_Voutz = "E" & i+1
    GoExcel.CellValue(ExcelFile, "Ark1",column_vinkel) = i
    GoExcel.CellValue(ExcelFile, "Ark1",column_Vinz) = Vinz
    GoExcel.CellValue(ExcelFile, "Ark1",column_Viny) = Viny
    GoExcel.CellValue(ExcelFile, "Ark1",column_Voutx) = Voutx
    GoExcel.CellValue(ExcelFile, "Ark1",column_Voutz) = Voutz
    i=i+1
End While
GoExcel.Save
Hi again
I missed to say that my parameter "Rotation" will change the geometry on my Inventor part. Parameter Viny, Vinz, Voutx and Voutz are parameters that vill be changed due to parameter Rotation so I only want to read them.
I want to use Inventor as an "advanced calculator".
BR/Goran
Now it works, but not sure why?!?
//Goran
GoExcel.CellValue(ExcelFile, "Ark1","E1") = "Voutz"
While (i<360)
    Parameter("rotation") = i
    iLogicVb.UpdateWhenDone = True
    ThisApplication.ActiveDocument.Update()
    GoExcel.CellValue(ExcelFile, "Ark1",column_Vinz) = Parameter("Vinz")
    GoExcel.CellValue(ExcelFile, "Ark1",column_Viny) = Parameter("Viny")
    GoExcel.CellValue(ExcelFile, "Ark1",column_Voutx) = Parameter("Voutx")
    GoExcel.CellValue(ExcelFile, "Ark1",column_Voutz) = Parameter("Voutz")
    GoExcel.Save
    i=i+1
End While
