Write iPropertie from .idw to part
I want to know if it possible to write an iProperty in the IDW to the iProperties of the part that is placed in the IDW.
The iProperty is the "Pagenumber" of the idw.
I have build an configurator which will print different IDWs with different pagenumbers and after processing, it needs to be written to the part number.
Cadmanto
Not on a normal day. Smiley Wink
The model drives the drawing, not the other way around.  Only way I can think of would be through iLogic.
What is your scenario?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
I want to try this through iLogic, but after trying and searching multiple times, i couldn't find any solution that will match this problem
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try suggestions in below blog link.
http://adndevblog.typepad.com/manufacturing/2018/05/ilogic-to-copy-iproperties-from-drawing-document-to-model-document.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Many many thanks. This link helped me to find my solution
mario.garzon
Community Visitor
Community Visitor
Just recovered this from google cache:
Sub Main()
	If Not ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		Messagebox.Show("Current document is not drawing docuemnt", "Inventor")
		Exit Sub
	End If
	Dim value_List As List(Of String) = New List(Of String)
	value_List.Add(iProperties.Value("Project", "Vendor"))
	value_List.Add( iProperties.Value("Project", "Stock Number"))
	value_List.Add(iProperties.Value("Project", "Project"))
	value_List.Add(iProperties.Value("Project", "Designer"))
	Dim oDoc As Document
	oDoc = ThisDrawing.ModelDocument
	If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		Update_Properties(oDoc,  value_List)
		Dim oAsyDoc As AssemblyDocument
		oAsyDoc = oDoc
		Dim oReferDoc As Document
		Dim occ As ComponentOccurrence
		Dim oDef As AssemblyComponentDefinition
		oDef = oAsyDoc.ComponentDefinition
		For Each occ In oDef.Occurrences
			If occ.SubOccurrences.Count = 0 Then
				oReferDoc = occ.ReferencedDocumentDescriptor.ReferencedDocument
				Update_Properties(oReferDoc, value_List)
			Else
				processAllSubOcc(occ,  value_List)
			End If
		Next
	Else If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
	End If
End Sub
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence , value_List As List(Of String))
	Dim oSubCompOcc As ComponentOccurrence
    For Each oSubCompOcc In oCompOcc.SubOccurrences
        If oSubCompOcc.SubOccurrences.Count = 0 Then
            oReferDoc = oSubCompOcc.ReferencedDocumentDescriptor.ReferencedDocument
			Update_Properties(oReferDoc,value_List)
        Else
			Update_Properties(oReferDoc ,value_List)
            Call processAllSubOcc(oSubCompOcc, value_List)
        End If
    Next
End Sub
Sub Update_Properties(oDoc As Document,   value_List As List(Of String))
	oDoc.PropertySets.Item("Design Tracking Properties").Item("Vendor").Value = value_List.Item(0)
	oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value = value_List.Item(1)
	oDoc.PropertySets.Item("Design Tracking Properties").Item("Project").Value = value_List.Item(2)
	oDoc.PropertySets.Item("Design Tracking Properties").Item("Designer").Value = value_List.Item(3)
	oDoc.Save()
End Sub
