Write flat pattern area parameter to each sheet metal in the assembly
ts2.cad3
ts2.cad3
Hi all, i get this error:"Object variable or With block variable not set" in this simple macro.
Someone have any tips?
Sub Main
Dim oAssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAssyDef As AssemblyComponentDefinition = oAssyDoc.ComponentDefinition
Dim oSSet As SelectSet = oAssyDoc.SelectSet
Dim oDoc As Inventor.Document
	For Each oDoc In oAssyDoc.AllReferencedDocuments
		'verify document type (we are interested in metal sheets only)
		If oDoc.ComponentDefinition.Type = kSheetMetalComponentDefinitionObject Then
			Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
			Dim oColl As ComponentOccurrencesEnumerator = oAssyDef.Occurrences.AllReferencedOccurrences(oDoc)
				If oColl.Count > 0 Then
					'select all found components
					Dim oOcc As ComponentOccurrence= oObj
					For Each oOcc In oColl
						Call cQM(oOcc, oDoc, oDef)
					Next oOcc
				End If
			End If
	Next
End Sub
Sub cQM(oOcc, oDoc, oDef)
	Dim oDocName As String = oDoc.DisplayName
'        If oCompDef.HasFlatPattern = False Then
'            oCompDef.Unfold
'			oCompDef.FlatPattern.ExitEdit
'            'Dim ACTD As Document = TryCast(ThisApplication.ActiveDocument, Document)
'            ACTD.Close()
'        End If
        Dim extents_area As Double = oDef.Flatpattern.Length * 10 * oDef.Flatpattern.Width * 10
        Dim sfr As Double = extents_area
        sfr = CStr(sfr)
        iProperties.Value(oDocName, "Custom", "QTA_MATERIALE") = sfr
		iProperties.Value(oDocName, "Custom", "DIMENSIONI") = ""
End Sub
Frederick_Law
Error on which line?
ts2.cad3
Frederick_Law
Error on every part?
One part don't have flat pattern?
ts2.cad3
Yes error on every part, all the part have already flat pattern except one, is there a way to create it for parts that don't have it? I noticed that if all the parts have a flat pattern the rule works
marcin_otręba
sorry, but whole code is messed up,
main error is in line 17 oObj not declared or set to any value.
also
iProperties.Value("part1:1", "Project", "Part Number")
"part1:1" - it is oOcc.name not oDoc.DisplayName - it will give error as well
this code should work for you:
Sub Main
	For Each oOcc As ComponentOccurrence In oAssyDef.Occurrences
		If oOcc.Definition.Document.ComponentDefinition.Type = kSheetMetalComponentDefinitionObject Then
			Call cQM( oOcc.Definition.Document)
		End If
	Next
End Sub
Sub cQM( oDoc As PartDocument)
Dim sfr As Double = oDef.FlatPattern.Length * 10 * oDef.FlatPattern.Width * 10
		Try
			oDoc.PropertySets.Item(4).Item("QTA_MATERIALE").Value = sfr
		Catch
			oDoc.PropertySets.Item(4).Add(sfr,"QTA_MATERIALE")
		End Try
		Try
			oDoc.PropertySets.Item(4).Item("DIMENSIONI").Value = ""
		Catch
			oDoc.PropertySets.Item(4).Add("","DIMENSIONI")
		End Try
End Sub
ts2.cad3
solved whit
If oDef.HasFlatPattern = False Then
oDef.Unfold
oDef.FlatPattern.ExitEdit
in the Sub cQM
