Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Window select project geometry
2 REPLIES 2
mat_hijs
441 Views, 2 Replies
Does anyone happen to have some code that allows me to project geometry using window selection? I want to project a lot of lines from one sketch to another which is quite tedious when I have to click each line separately. Especially because these lines are all on top of construction lines that I don't want to project. But this means I have to use select other half of the time.
2 REPLIES 2
JelteDeJong
in reply to: mat_hijs
you can try this. Run this rule. Select the original sketch in your browser then select the target sketch in your browser. An watch the magic...
Dim doc As PartDocument = ThisDoc.Document
Dim orgSketch As PlanarSketch = ThisApplication.CommandManager.
	Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select original sketch")
Dim newSketch As PlanarSketch = ThisApplication.CommandManager.
	Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select new sketch")
For Each ent As SketchEntity In orgSketch.SketchEntities
    If ent.Construction Then Continue For
    If ent.Type = ObjectTypeEnum.kSketchPointObject Then Continue For
    newSketch.AddByProjectingEntity(ent)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
mat_hijs
in reply to: JelteDeJong
I don't need to project every line that is not a construction line, but this seems to work and deleting projected lines that I don't need is a lot faster than projecting them one by one since this can be done with window selection.
Thank you very much!
