Where's my Inventor Macro?
jR0sal3s
jR0sal3s
Hello all....
I hope somebody can help me on this.
I have directed my Default VBA project to where my .ivb is through Tools/App Options/File tab and Default VBA project.
Now, when i tried to set my shortcut through, Customize User Commands/Keyboard/Macros category - it is empty and couldn't find any of my macros!...
I have it working before...and with other computers, but i got this issue with one computer...so, What did i missed?
Regards..
JR
Replies (11)
bradeneuropeArthur
What is the file-size of your .ivb file, you are loading?
Arthur Knoors
Autodesk Affiliations:
jR0sal3s
Should it matter....? Its 1243 kb only.
What i don't understand is that the macro is working in the other computer, however with the other two computers, it is not. It is just because i couldn't just see the macro.
Perhaps, the program that reads vba is corrupted?
GeorgK
You could try to repair it:
Close Inventor and install from your source
64-bit:  \3rdParty\x64\VBA\Vba7.MSI.
32-bit:  \3rdParty\x86\VBA\Vba7.MSI.
Could you post the file? Maybe it's corrupt.
There is a similar case:
https://forums.autodesk.com/t5/inventor-customization/2014-64-bit-vba-crashing-on-program-launch-ran...
bradeneuropeArthur
If the VBA project file was really empty than the size should be small.
I only wanted to check if there are modules in the VBA project file.
Arthur Knoors
jR0sal3s
The .ivb file is fine...it actually works in my computer...but when i tried it to another computer, I was able to direct the file path to the .ivb file but when i tried to assign a shortcut key to the macro (in the customize toolbar) it doesn't show in there...it's just blank.
jR0sal3s
the .ivb file is working fine in other computer, it is just specific to the other 2 computers...I might just have to re-install it somehow if all else doesn't work, it is just I wanted to know what is causing this and fix this without re-installing everything.
jR0sal3s
bradeneuropeArthur
Can you find any macro under the macro button in the ribbon of inventor?
Arthur Knoors
jR0sal3s
bradeneuropeArthur
What happens if you pres ALT + F11 within inventor, is it opening VBA editor?
Arthur Knoors
jR0sal3s
actually, Alt+F11 opened the VBA editor and i found out there was nothing on it..
I overwrite it with the working .ivb on another computer and it all fixed the problem...so Thanks a lot for your time...
