Where is New Feature Face Name in Inventor 2019 API located
martin_winkler
martin_winkler
I could not find the new Feature Property Face Name in the API.
Is anyone knowing where i could find it and how the property is named in the API?
Replies (12)
chandra.shekar.g
Autodesk Support
Autodesk Support
@martin_winkler,
Hoping that below suggestions in forum discussion may be helpful to read face name.
https://forums.autodesk.com/t5/inventor-customization/geometry-labels-inventor-2019/m-p/8350452#M904...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
clutsa
From what I can tell the feature property face name isn't new to the API it's the same stuff that's been there for years. The "new" part is simply that they added a user interface to make it easier to get to. The face names are stored using attributes and attributeSets.
Here's a rough idea how to get to them.
Dim part1Def As PartComponentDefinition = part1.Definition 'my part1 came from an assembly component occurrence
Dim oFaces As Faces = part1Def.SurfaceBodies(1).Faces
Dim tempFace As Face
For Each oFace In oFaces
	AttSets = oFace.AttributeSets
	If AttSets.NameIsUsed("iLogicEntityNameSet") Then
		AttSet = AttSets.Item("iLogicEntityNameSet")
		For Each Att In AttSet
			If Att.Value() = "yourNamedFeature" Then 'change name here
				tempFace = oFace
				Logger.Debug("tempFaceID Set" & tempFace.InternalName)
			End If
		Next
	End If
Next
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
martin_winkler
@clutsa
Thanks, that was the hint I needed. I have written two examples in VBA how to get the names of all surfaces and how to get the names of selected surfaces. I need this in order to name a sketch according to the area from which it is originated.
Sub Get_AllNames_from_Faces()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oFaces As Faces
Set oFaces = oCompDef.SurfaceBodies(1).Faces
Dim AttSets As AttributeSets
Dim AttSet As AttributeSet
For Each oface In oFaces
 Set AttSets = oface.AttributeSets
  Set AttSet = AttSets.item("iLogicEntityNameSet")
    Debug.Print ("Face Value: " & Att.Value)
  Next
 End If
Next
End Sub
Sub Get_SelectedNames_from_Faces()
Dim CompDef As ComponentDefinition
Set CompDef = oDoc.ComponentDefinition
Dim oSelect As SelectSet
Set oSelect = oDoc.SelectSet
Dim oFaces As Faces
Set oFaces = CompDef.SurfaceBodies(1).Faces
For Each item In oSelect
 Set AttSets = item.AttributeSets
   If Att.Name = "iLogicEntityName" Then
    'Get only the displayed Name of the Face
   End If
  Next
 End If
Next
End Sub
Best Regards Martin
Hi All -
I'm trying to change the appearance (color) of a "named face" using iLogic.
For instance: "Face" = (Autodesk Appearance Library) Bamboo, "Back" = (Autodesk Appearance Library) Cardboard
Is this possible?
Actually, I'd like to be able to change the color of the "named face" by assigning a material to it....
Thanks.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to change appearance of named face (In this code, "Top" is considered as named face).
Sub Main()
	Dim oAsset As Asset
	oAsset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item("Cardboard")
	Dim oDocAsset As Asset
	Try
		oDocAsset = oDoc.AppearanceAssets.Item("Cardboard")
	Catch
		oAsset.CopyTo(oDoc)
	End Try
	Dim oFaces As Faces
	Dim oFace As Face
			    If Att.value = "Top" Then
					oFace.Appearance = oDocAsset
				End If
			  Next
		 End If
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
That's brilliant, thanks.
Let's say that instead of "Cardboard", I need to reference the Appearance from a selected material?
I have a multi-level parameter (Top_Material) which is linked to the (Autodesk Material Library), where the user can select a material/appearance for the "Top".
So if the user selects Plaster, then the appearance for Plaster would be assigned.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Try below iLogic code to select the material from the list.
 Sub Main()
	Dim oList As ArrayList = New ArrayList()
	Dim oMaterial As Asset
	For Each oMaterial In ThisApplication.AssetLibraries.Item(2).AppearanceAssets
		oList.Add(oMaterial.DisplayName)
	Next
	If oDoc.DocumentType = kPartDocumentObject Then
		Dim oPartCompDef As PartComponentDefinition
		oPartCompDef = oDoc.ComponentDefinition
		Dim oParams As Parameters
		oParams=oPartCompDef.Parameters
		Dim oUserParams As UserParameters
		oUserParams=oParams.UserParameters
		Dim oAwesomeParameter As Parameter
		Try
			otester = oUserParams.Item("material")
		Catch
			oInsulationType=oUserParams.AddByValue("material", oList.Item(1), kTextUnits)
		End Try
    End If
	Parameter.Param("material").ExposedAsProperty = False
	Parameter.Param("material").IsKey = True
	MultiValue.List("material") = oList
	selected_mat = InputListBox("Choose Part material", MultiValue.List("material"),oList.Item(1), Title := "Part material", ListName := "Available Standard materials")
	Dim oAsset As Asset
	oAsset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item(selected_mat)
	Try
		oDocAsset = oDoc.AppearanceAssets.Item(selected_mat)
	Catch
		oAsset.CopyTo(oDoc)
	End Try
	Dim oFaces As Faces
	Dim oFace As Face
				End If
			  Next
		 End If
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
MjDeck
@martin_winkler , @Anonymous , @clutsa
Instead of going to the AttributeSets, you can use the NamedEntities iLogic API.
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(ThisDoc.Document)
Mike Deck
Software Developer
Autodesk, Inc.
liminma8458
Hi, Mike,
Can I use this iLogic API in VB.NET in any way?
Limin
Inventor pro 2023 64 bit update 2.1; Windows 10 pro 64 bit version 21H2; Office 2013 32 bit
MjDeck
Limin,
 Yes, you can access this and other iLogic API from VB.NET. Where is your code running?
1) add-in
2) external EXE
3) DLL loaded by iLogic
The best way to access it is different for each.
Mike Deck
Software Developer
Autodesk, Inc.
liminma8458
Mike,
I want to use this iLogic API function directly from an Add-in of VB.NET (of course, I need to put the API as a reference somewhere in the add-in). So I don't need to put this function in an iLogic rule then call the rule first.
Limin
MjDeck
Add references to these DLLs (in %ProgramFiles\Autodesk\Inventor 2019\Bin)
Autodesk.iLogic.Core.dll
Autodesk.iLogic.References.dll
Set the reference properties:
Copy Local : False
Specific Version : False
Then in your code:
Imports Autodesk.iLogic.Core
Imports Autodesk.iLogic.Interfaces
If (iLogicCentral.Instance IsNot Nothing) Then
	Dim iLogicAuto As IiLogicAutomation = iLogicCentral.Instance.ExternalApi
	'use iLogicAuto ...
End If
If the iLogic add-in is loaded, then iLogicCentral.Instance shoudl be available.
Here's the documentation for IiLogicAutomation .
Mike Deck
Software Developer
Autodesk, Inc.
