what would I need to add to this iLogic code to make the answer show up in the parameters as a reference dimension?
chris
chris
martin_winkler
Why should this be a reference parameter? You can write the value in a Text type custom parameter. Or into a custom iProperty.
chris
@martin_winkler Okay, I was just trying to get it as something I could then reference in parameters. this code, in its current form, only gives me a message answer I just wanted to be able to use the answer in formulas
A.Acheson
Hi @chris
You would need to have a dimension in a sketch and have it set to driven. Or have a parameter derived from another part.
If this is just a calculation you could just leave it in the code or make a comment to say what the user needs to do E.G do not touch. Unfortunately there is no way to make it read only if I understand your intention.
Regards
Alan
Curtis_Waguespack
Hi @chris
edit: see @WCrihfield's post below to add a reference parameter
To make it a reference dimension, I think you would need to have or add a sketch dimension and set it to be driven.
To pass the result to a user parameter, you could use something like this to look for the parameter and create it if not found.
Dim num1 As Double = 7
Dim num2 As Double = 9
Dim oResult As Double = Math.Sqrt(num1 + num2)
oName = "My_SQRT_Result"
Dim oUserParams As UserParameters
If ThisDoc.Document.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
	oUserParams = ThisDoc.Document.Parameters.UserParameters
Else
	oUserParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
End If
Dim oTest As String = ""
Try : Parameter(oName) = oResult : Catch : oTest = "not found" : End Try
If oTest = "not found" Then
	oUserParams.AddByValue(oName, oResult, UnitsTypeEnum.kUnitlessUnits)
	'oUserParams.AddByValue(oName, oResult, UnitsTypeEnum.kInchLengthUnits)
End If
'assumes Length is an inch based parameter
'use * 1 in to convert untiless to inches
Parameter.Param("Length").Expression =  oName & "* 1 in"
InventorVb.DocumentUpdate()
I hope this helps.
Curtis
Frederick_Law
Or add it to 'User Parameter'
WCrihfield
If a reference parameter is wanted, why not just create one directly, using the ReferencedParameters.AddByValue or ReferenceParameters.AddByExpression methods?  This seems like the simplest, and most direct way of doing what was asked for in the original post.
Dim oPDoc As PartDocument = ThisDoc.Document
Dim RParams As ReferenceParameters = oPDoc.ComponentDefinition.Parameters.ReferenceParameters
RParams.AddByExpression("123.456 in", "in", "MyRefParam")
Wesley Crihfield
(Not an Autodesk Employee)
