What is a better name for this command?
HideoYamada
HideoYamada
This post isn't exactly about Inventor Customization. But I need your help in this forum.
I'm making new command about Derived Part.
Please see the video.
https://knowledge.autodesk.com/community/screencast/9ecc5a2e-f2f6-446d-8bc2-fcbde40ec0db
For reference, the standard command name is PartDerivedComponentCmd.
I made some candidate names.
1) PartAlignedDerivedComponentCmd.
2) PartLocatedDerivedComponentCmd.
3) PartUcsMatedDerivedComponentCmd.
4) PartUcsDerivedComponentCmd.
Please let us know your opinion, not limited to the above candidates.
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
YuhanZhang
I prefer PartUcsDerivedComponentCmd. Also you can add your company or addin name to the command name to avoid name confliction in case other people pick the same name, like "YourCompanyName:PartUcsDerivedComponentCmd" or "YourAddInName:PartUcsDerivedComponentCmd".
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
chandra.shekar.g
Autodesk Support
Autodesk Support
@HideoYamada,
All command list is attached with this post. Command name can be chose based on your choice. But, name should not be listed in attached command list.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
HideoYamada
Hello Rocky,
Thank you for your advice.
I will make this AddIn complete and submit to AppStore.
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
HideoYamada
Hello Chandra,
Your list will be helpful.
Thank you!
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
