Views added via API lose BOM information
c_hoppen
c_hoppen
Hello.
As the title says, views lose their connection to the BOM when I create views with the API.
DrawingView iso1View = sheet.DrawingViews.AddBaseView(modelDoc as _Document,
    centerIso1, scale,
    ViewOrientationTypeEnum.kIsoTopRightViewOrientation,
    DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle,
    "", null, options);
As a result, I cannot place a BOM. The line
PartsList partsList = sheet.PartsLists.Add(iso1View, tg.CreatePoint2d(0, 0));
throws an exception.
Very strange: When I try to manually place a balloon after creating the views, Inventor asks me for the BOM. See video. I have never seen this dialog before.
This only happens with a specific customer data set. It works with other example assemblies. This does not occur when I create the views manually. This is independent of the drawing template.
Inventor 2024.3.3
Regards
Christoph
JMGunnar
Check BOM in Assembly
Best Regards Johan
		oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(postionX, postionY)
		Dim partsListBomType As PartsListLevelEnum = 46593
		'''Name					Value	Description
		'kFirstLevelComponents	46593	First level components.
		'kPartsOnly				46594	Parts only.
		'kStructured			46593	Structured first level components.
		'kStructuredAllLevels	46595	Structured all components.
		Dim oPartsList As PartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint,partsListBomType)
c_hoppen
Thanks for the hint.
Strangely, it worked with all other test assemblies without the optional parameter.
kFirstLevelComponents appears to be deprecated. It's not exposed through the API.
Have a great holiday!
