hi, does this work or you?
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
' Make a list of the views. For use later
Dim knowViews As List(Of String) = New List(Of String)
For Each view As DrawingView In doc.ActiveSheet.DrawingViews
knowViews.Add(View.Name)
Next
' Create a drawingview
Dim sFileName = oPartTest.FullFileName
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, sFileName)
Dim oTest = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingBaseViewCmd")
oTest.Execute2(True)
' find the view that was just added and (re)start command
If (knowViews.Contains(View.Name) = False) Then
doc.SelectSet.Clear()
doc.SelectSet.Select(View)
ThisApplication.CommandManager.ControlDefinitions.Item("DrawingViewEditCtxCmd").Execute()
Exit For
End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
