VC++ addin to create a ClientFeature
I've been trying to create a ClientFeature with a c++ addin for a few hours, without success.
Here is a sample of my code :
Document * doc = m_pApp->GetActiveDocument();
PartDocument * partDoc;
HRESULT hr = doc->QueryInterface(__uuidof(PartDocument), (void**)&partDoc);
if (!SUCCEEDED(hr) || !partDoc) return E_FAIL;
PartComponentDefinition * oCompDef = partDoc->ComponentDefinition;
if(!oCompDef) return E_FAIL;
PartFeatures * partFeatures = oCompDef->GetFeatures();
if (!partFeatures) return E_FAIL;
ClientFeatures * clientFeatures = partFeatures->ClientFeatures;
if (!clientFeatures) return E_FAIL;
CComPtr<ClientFeatureDefinition> clientFeatureDef;
CComBSTR featType = "FeatName";
VARIANT nothing; hr = clientFeatures->CreateDefinition(featType, nothing, nothing, nothing, &clientFeatureDef); // crash
I use "nothing" because these arguments are optional but as the C++ function return the result in the last argument I have to provid the previous arguments.
When trying to execute this code, Inventor throw an exception and crash at the "CreateDefinition" line.
I also tried with
_bstr_t featTypebstr = "FeatName";
clientFeatureDef = clientFeatures->MethodCreateDefinition(featTypebstr);
and got the same result (crash).
If anyone could tell me what I am doing wrong that would be really helpful.
Thank you,
Thomas
Little update :
I tried to do the exact same thing with C# and it worked first try. Here is the code (very simple) :
app = AddInServer.InventorApplication;
var activePart = (PartDocument) app.ActiveDocument;
PartComponentDefinition compDef = activePart.ComponentDefinition;
PartFeatures pFeats = compDef.Features;
ClientFeatures cFeatures = pFeats.ClientFeatures;
ClientFeatureDefinition featDef = cFeatures.CreateDefinition();
ClientFeature cFeat = cFeatures.Add(featDef, "testClientFeatID");
To me it looks like the C++ API is not workink properly...
I have the same problem and C# or VB isn't an option for me, can anyone help me before I switch to another product than Inventor ?
Up
Anyone knows if ClientFeatures.CreateDefinition works in C++, or can give a workaround if it's not the case ?
