VBA vault UndoCheckoutTop only working once?
08:46 AM
- Mute
- Permalink
- Report
I have written a macro to open and look through drawings in inventor. I would like it to UndoVaultCheckoutTop for certain drawings which do not require changing however my macro will only undocheckout for the first drawing and does not work the for the subsequent drawings.
Here is a shortened version of code containing the important part.
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If oDoc.DocumentType = kDrawingDocumentObject Then
oDoc.Activate
''Sub to look through the drawing
End If
Next
''In the sub that looks through the drawing
''If unchanged then
Set ctrdef = ThisApplication.CommandManager.ControlDefinitions.Item("VaultUndoCheckoutTop")
ctrdef.Execute
DoEvents
invDoc.Close (True)
DoEvents
''End if Each document that is unchanged does get here and is closed as it should be however only the first one has the checkout undone. The rest are closed but remain checked out. Is there any reason that this happens/ how can I fix this?
Thank you.
