[VBA] SetInspectionDimensionData Blank Label Issue
03:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Gday all,
My goal is to create macros for everything I use the most so i can assign them single key hotkeys to boost my productivity. So I got the following code to set a dimension as an inspection with an angular border, but my issue is it creates a segment (vertical line) for the label even when the label it's set to be blank. Manually editing the dimension shows that the label is blank but if i press delete it removes the segment line.
Sub Dimension_Inspection() Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oSSet As SelectSet Set oSSet = oDoc.SelectSet 'reference to the selected dimension Dim oDim As LinearGeneralDimension Set oDim = oSSet.Item(1) Dim Shape As InspectionDimensionShapeEnum Dim Label As String Dim Rate As String Shape = kAngularEndsInspectionBorder Label = "" Rate = "" oDim.IsInspectionDimension = True oDim.SetInspectionDimensionData Shape, Label, Rate End Sub
See the highligted segment. it's unnecessary and makes my drawings look inconsistant.
