[VBA] SetInspectionDimensionData Blank Label Issue
Gday all,
My goal is to create macros for everything I use the most so i can assign them single key hotkeys to boost my productivity. So I got the following code to set a dimension as an inspection with an angular border, but my issue is it creates a segment (vertical line) for the label even when the label it's set to be blank. Manually editing the dimension shows that the label is blank but if i press delete it removes the segment line.
Sub Dimension_Inspection()
  Dim oDoc As DrawingDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oSSet As SelectSet
  Set oSSet = oDoc.SelectSet
  'reference to the selected dimension
  Dim oDim As LinearGeneralDimension
  Set oDim = oSSet.Item(1)
  Dim Shape As InspectionDimensionShapeEnum
  Dim Label As String
  Dim Rate As String
  Shape = kAngularEndsInspectionBorder
  Label = ""
  Rate = ""
  oDim.IsInspectionDimension = True
  oDim.SetInspectionDimensionData Shape, Label, Rate
End Sub
See the highligted segment. it's unnecessary and makes my drawings look inconsistant.
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
I too could reproduce the issue: http://www.screencast.com/t/XuivQmtlXIAE, and have logged it in our database under #54707 so that hopefully it will get sorted in a later release.
Unfortunately, I cannot think of a nice workaround - other than ugly Windows messaging, bringing up the dialog, sending DELETE KEY, pressing OK. :-s
(which is also not very robust :-s)
Sorry for the bad news.
Cheers,
Adam Nagy
Autodesk Platform Services
JarFu
I can reproduce this issue with Inventor 2015 as well. The issue disappeared in Inventor 2016, could you please have a try when you get the new build? And please let us know if you expect the fix in Inventor 2015 SP or Update. Thank you!
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
