VBA (IV2018): get all corners of a Part via macro
fullevent
fullevent
what is the easiest way to read the coordinates from each corner of an ipt?
Is this even possible or do I have to calculate the coordinates via the sketch elements and extrusions?
Aattached an ipt.
I have many such IPTs and they all build up identically.
Thanks in advance.
Aleks
Aleksandar Krstic
Produkt- und Projektmanager
fullevent
I found "Vertices".. didnt know about that property.
This works for me:
Private Sub read_all_corner_ipt()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oCompDef As ComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    Dim oVert As Vertices
    Set oVert = oCompDef.SurfaceBodies.Item(1).Vertices
    sTxt = "x" & vbTab & vbTab & "y" & vbTab & vbTab & "z"
    For Each Item In oVert
        sTxt = sTxt & vbCr & Round(Item.Point.x, 2) & vbTab & vbTab & Round(Item.Point.y, 2) & vbTab & vbTab & Round(Item.Point.z, 2)
    Next
    MsgBox sTxt
End Sub
EDIT: Now it works for me
Aleksandar Krstic
