VBA code - Step export from idw
Hi All,
 I need the code that would open ipt or idw from first sheet first view and generate step file from it.
Then after export switch bacjk to idw as active document.
Also I am using code t update part:
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
oDocument.Update
 But this code do not update idw - all sheets
Any help woul be great.
Regards
Hi All
I have found this code:
'Update Drawing
Dim oDocument As Inventor.DrawingDocument
Dim oSheet As Inventor.Sheet
oSheet = oDocument.Sheets(1)
If oDocument.RequiresUpdate Then
oDocument.Update
oDocument.Save
End Sub
 But It fails at:
 Invalid use of property.
Because this property is an object. Therefore, in vba, you must use "Set" keyword.
Set oSheet =  oDocument.Sheets(1)
