Announcements
VBA code for replacing sketch symbols on the drawing
Hi Guys,
I need help with the code (complete beginner :-)) PLEASE.
I got a code already (attached) from the friend that changes drawing to "for construction": changes rev to 0, fills "issued for construction" in revision table and updates dates etc.
It is possible to add to it a code that:
- replace symbol that is currently on the first page only on the drawing named 'A3 For Approval' to
- symbol named 'A3 For Construction'?
You help would be greatly appreciated.
Thank you very much Paul
Tony_Yates
Hi Paul,
Try this:
'Dim oDoc As DrawingDocument
Dim oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
     Dim oSketchedSymbolDef As SketchedSymbol
    For Each oSketchedSymbolDef In oSheet.SketchedSymbols
     If oSketchedSymbolDef.Name = "A3 For Approval" Then
        oSketchedSymbolDef.Delete 'It will delete all the sketched symbols
   Next
Next
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
' Obtain a reference to the desired sketched symbol definition.
Dim oSketchedSymbolDef As SketchedSymbolDefinition _
       = oDrawDoc.SketchedSymbolDefinitions.Item("A3 For Construction")
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
'create insertion point, coordinates - in cm !
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(40.195195, 10.5)
Dim oSketchedSymbol As SketchedSymbol _
       = oSheet.SketchedSymbols.Add( _
             oSketchedSymbolDef, _
             oInsertionPoint, _
             0, 1, Nothing)
change the insertion point number to position where you like it.
Also noticed your stamp name is spelt incorrect. "A3 For Constrcuction" so correct that first.
Thank you Tony,
I did try and getting this:
Tony_Yates
Hi Paul,
Sorry I just added two rules together.
Try This:
Dim oSheet As Sheet
   Next
Next
Dim oSketchedSymbolDef1 As SketchedSymbolDefinition _
       = oDoc.SketchedSymbolDefinitions.Item("A3 For Construction")
             oSketchedSymbolDef1, _
             oInsertionPoint, _
             0, 1, Nothing)
Hi Tony,
Thank you, We are almost there :-), it deletes 'for approval' at the first page BUT places 'for construction' at the last page only. It works perfectly when IDW has only one sheet.
Tony_Yates
Hi Paul,
changed to active sheet
Dim oSheet As Sheet
   Next
Next
       = oDoc.ActiveSheet.SketchedSymbols.Add( _
             oInsertionPoint, _
             0, 1, Nothing)
Thank you VERY MUCH for help Tony, it works perfectly, It will save me hips of time, have a nice day :slightly_smiling_face:
