VB.NET to C#
VB.NET to C#
Daan_M
VB.NET to C#
Daan_M
Hi forum,
I made a VB.NET code for Inventor last week (with help from forum members), which runs fine by the way!
I tried translating it to C# but i cant solve the errors i am getting, since im new to coding i find it diffecult to interpret the error messages.
If anyone can help me out it's greatly appreciated
Below here is a part the code in C#, below that the error messages, its about CS1955 and CS1061
using System;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using Inventor;
using System.ComponentModel.Design.Serialization;
using Autodesk.iLogic.Interfaces;
        public void rulerunner()
                string MyRuleName = "cmdRead";
                string iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}";
                ApplicationAddIn iLogicAddin;
                object iLogicAutomation = null; // As IiLogicAutomation = Nothing
                try
                    iLogicAddin = _invApp.ApplicationAddIns.ItemById(iLogicAddinGuid); //doesnt work?
                    iLogicAutomation = iLogicAddin.Automation;
                catch (Exception ex)
                    MessageBox.Show("Unable to access iLogic addin " + ex.Message);
                try
                    iLogicAutomation.RunRule(oDoc, MyRuleName); //doesntwork?
                catch
                    MessageBox.Show("There is no rule called " + MyRuleName);
Michael.Navara
This is because ItemById is not a function but property with argument
Change
to
_invApp.ApplicationAddIns.ItemById[iLogicAddinGuid];
That's all 🙂
Daan_M
Thanks! that solves a part of 🙂
i still need help with the following lines:
 try
                _invApp = (Inventor.Application)Marshal.GetActiveObject("Inventor.Application");
Error CS0117 'Marshal' does not contain a definition for 'GetActiveObject' WindowsFormsApp1 C:\Users\daanm\Desktop\vrijdag\WindowsFormsApp1\Form1.cs 38 Active
try
                    Autodesk.iLogic.Interfaces.IiLogicAutomation.RunRule(oDoc, MyRuleName);
Error CS0120 An object reference is required for the non-static field, method, or property 'IiLogicAutomation.RunRule(Document, string)' WindowsFormsApp1 C:\Users\daanm\Desktop\vrijdag\WindowsFormsApp1\Form1.cs 88 Active
Michael.Navara
I don't know what the Marshal is in your context. I'm using this piece of code to get active Inventor.Application object
 //Get running inventor
private const string InventorProgID = "Inventor.Application";
result = System.Runtime.InteropServices.Marshal.GetActiveObject(InventorProgID) as Inventor.Application;
in the second example you try to call method on object definition but you mast call on object instance. Similar to this:
