VB.net error on ported VBA code
pball
pball
I have a VBA script that would save and replace all occurrences of a selected component. I've since ported that to my VB.net addin and now I'm having issues. When I use the script from my VB.net addin I get an illegal error when the script replaces parts with ilogic triggers in them. The exact same VBA does not cause this error. The error does not cause the operation to fail but it causes extra clicks and would probably scare the average person.
Is there a different way to find and replace that might not cause this or a way to prevent ilogic triggers from running when replacing components.
Error Message:
"Illegal attempt to create identified child transaction inside an unidentified transaction"
Imports Inventor
Module Save_Replace_All
    Public Sub SaveReplaceAll()
        'Checks if open document is assembly
        If (ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject) Then
            MsgBox("This is NOT an assembly document!", vbExclamation)
            Exit Sub
        End If
        Dim oPart As ComponentOccurrence
        Dim oPartDoc As Document
        Dim NewFilePath As String
        oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select the part to save and replace all.")
        If (oPart Is Nothing) Then Exit Sub
        oPartDoc = oPart.Definition.Document
        Dim oFileDlg As Inventor.FileDialog = Nothing
        Call ThisApplication.CreateFileDialog(oFileDlg)
        'check file type and set dialog filter
        If oPartDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
        ElseIf oPartDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
        End If
        oFileDlg.InitialDirectory = ThisApplication.FileLocations.Workspace
        oFileDlg.FileName = Filename(oPartDoc.FullFileName)
        oFileDlg.CancelError = True
        Call oFileDlg.ShowSave()
        If oFileDlg.FileName <> "" Then
            NewFilePath = oFileDlg.FileName
        Else
            Exit Sub
        End If
        ThisApplication.SilentOperation = True
        Call oPartDoc.SaveAs(NewFilePath, True)
        ThisApplication.SilentOperation = False
'ERROR OCCURS BELOW Dim fd As DocumentDescriptor For Each fd In ThisApplication.ActiveEditDocument.ReferencedDocumentDescriptors If (fd.FullDocumentName = oPartDoc.FullFileName) Then fd.ReferencedFileDescriptor.ReplaceReference(NewFilePath) End If Next 'Update browser names 'UBN() End Sub End Module
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
pball
I'm using ThisApplication all over my addin so I don't see how that is the issue.
pball
Well this was an easy fix after a bit more searching.
Just replace the loop at the end with the following code, which I found in a thread of mine asking for help while creating this script.
oPart.Replace(NewFilePath, True)
