vb.net- adding ribbon panel to existing tab
Eyal.Admon
Eyal.Admon
Hi Everyone,
I'm trying to add a costume panel to the tools tab in drawing document ribbon for my add-inand keep getting and error.
The line that throws the error is marked below with an arrow
note: I have used the same lines to add a panel to part and assembly document ribbons and it worked just fine.
' Get the ribbon.
Dim drawingRibbon As Inventor.Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Drawing")
' Get the "Tools" tab.
Dim drawingtoolstab As Inventor.RibbonTab = partRibbon.RibbonTabs.Item("id_TabTools")
' Check to see if the "MySample" panel already exists and create it if it doesn't.
Dim customPanel_drawing As Inventor.RibbonPanel = Nothing
Try
customPanel_drawing = drawingRibbon.RibbonPanels.Item("MySample")
Catch ex As Exception
End Try
If customPanel_drawing Is Nothing Then
'Create a New panel.
customPanel_drawing = drawingtoolstab.RibbonPanels.Add("Sample", "MySample", g_addInClientID)  <-------
End If
bradeneuropeArthur
Does this help?
https://forums.autodesk.com/t5/inventor-customization/adding-buttons-to-the-same-custom-ribbon-panel...
Arthur Knoors
Autodesk Affiliations:
Eyal.Admon
i figured it out.
i had a mistake in the line:
the "partRibbon.RibbonTabs.Item("id_TabTools")" should have been :
drawingRibbon .RibbonTabs.Item("id_TabTools").
stupid mistake...
