Using the PDF Translator with Inventor 2016 API
I am trying to write a VBA function that saves PDF files automatically. I have been using Document.SaveAs(), however I need to be able to control the sheet range that is exported. My function is as follows:
  Public Sub SaveAsPDF(ByVal doc As Document)
        Dim oPDFAddIn As TranslatorAddIn
        oPDFAddIn = _invApp.ApplicationAddIns.ItemById _
        ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
        Dim oContext As TranslationContext
        oContext = _invApp.TransientObjects.CreateTranslationContext
        oContext.Type = kFileBrowseIOMechanism
        Dim oOptions As NameValueMap
        oOptions = _invApp.TransientObjects.CreateNameValueMap
        Dim oDataMedium As DataMedium
        oDataMedium = _invApp.TransientObjects.CreateDataMedium
        If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
            oOptions.Value("All_Color_AS_Black") = 1
            oOptions.Value("Remove_Line_Weights") = 1
            oOptions.Value("Vector_Resolution") = 400
            oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
        End If
        'Set the PDF target file name
        oDataMedium.FileName = "C:\test.pdf"
        'Publish document
        oPDFAddIn.SaveCopyAs(doc, oContext, oOptions, oDataMedium)
    End Sub
When I run the function, passing it the open document (which is a drawing) I get a message in Inventor that says "Failed to publish DWF file" and when I click cancel I get the following error in my MSVS debugger on the oPDFAddIn.SaveCopyAs(doc, oContext, oOptions, oDataMedium) line:
I verified that {0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4} is the PDF translator ID, and even tried {0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}, which is the DWF translator.
Any guidance would be much appreciated!
Rohan Jhunjhunwala
ekinsb
The first argument to HasSaveCopyAsOptions should be the document, not the DataMedium object.  Here's a version of your function that is working for me to print sheet 2 and 3.
Public Sub SaveAsPDF2(ByVal doc As Document)
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    ' Create a NameValueMap object
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(doc, oContext, oOptions) Then
        oOptions.value("All_Color_AS_Black") = 0
        oOptions.value("Remove_Line_Weights") = 0
        oOptions.value("Vector_Resolution") = 400
        oOptions.value("Sheet_Range") = kPrintSheetRange
        oOptions.value("Custom_Begin_Sheet") = 2
        oOptions.value("Custom_End_Sheet") = 3
    End If
    'Set the destination file name
    oDataMedium.filename = "c:\temp\test2.pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(doc, oContext, oOptions, oDataMedium)
End Sub
Brian Ekins
Mod the Machine blog
Thanks for the response!
I replaced the line If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) with If oPDFAddIn.HasSaveCopyAsOptions(doc, oContext, oOptions), but I still received the same error. I even copy and pasted the code in the above post, and still received the same error.
I've resorted to using Foxit PDF printer for now, but I would much rather use the Inventor Translator so that Foxit installation is not a prerequisite for using my application.
Rohan Jhunjhunwala
ekinsb
The code that I pasted in works for me.  There must be something different on your system that's causing the problem.  Unfortunately, I don't have any ideas what that might be.  Do you have access to another computer that you could try it on to see if it's somehow machine specific?
Brian Ekins
