Using iLogic to create a linear dimension between two ProxyWorkPoint's
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As the title, I have created proxy work points and I wish to create a linear dimension between them. The gap in my knowledge is how I turn the WorkPointProxy's into a GeometeryIntent's.
Dim oModelDoc = ActiveSheet.View(viewname).ModelDocument Dim oAssemblyDoc As AssemblyDocument = oModelDoc Dim oPartOcc = oAssemblyDoc.ComponentDefinition.Occurrences.ItemByName("my part") 'Name of part in assembly Dim oPartDoc As PartDocument = oPartOcc.Definition.Document Dim oNamedEntities = iLogicVb.Automation.GetNamedEntities(oPartDoc) oDetailView = oSheet.DrawingViews.Item(2)'1 for main view, 2 for detail view. Dim oGenDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions Dim oWPN3 As WorkPoint = oNamedEntities.FindEntity("WPN3") Dim oWPN3Proxy As WorkPointProxy oPartOcc.CreateGeometryProxy(oWPN3, oWPN3Proxy) Dim oWPN2 As WorkPoint = oNamedEntities.FindEntity("WPN2") Dim oWPN2Proxy As WorkPointProxy oPartOcc.CreateGeometryProxy(oWPN2, oWPN2Proxy) oGenDims.AddLinear(oTG.CreatePoint2d(5,5), oWPN2, oWPN3)
If you look at the last line I have inserted two WorkPointProxy's as my GeometryIntent's. I know this is wrong. How do I make the conversion to the correct data type?
Many thanks,
Harvey
