Using goto in ilogic
SharkDesign
Mentor Mentor
SharkDesign
I've used the goto command successfully in the past, but I'm having trouble across multiple subs, I assume it doesn't like this?
[Sub main
start: (this is where I am defining my label)
code
code
code
[Sub
code
code
goto start (this is where I want to send the code back to the label)
Basically what I'm doing is running the code from this page https://forums.autodesk.com/t5/inventor-customization/ilogic-place-a-part-and-define-rotation/m-p/89...
But instead of user input the xyz is defined.
Then if a certain parameter is true it redefines the xyz and 'goto' the begging of the code to run again.
It does this 8 times depending on whether these parameters say true or false.
The error I am getting is that the goto label is not defined and the only reason I can see for this is that the label and the goto are in different subs but I'm not clever enough to work out how to fix this.
  Inventor Certified Professional
SharkDesign
Class ThisRule
Sub Main
' File path to use
oPath = "path and part"
'get user input - units are cm
oX = -RobotFrameWidth/2-UprightBoxWidth
oY = 2504
oZ = ( RobotFrameDepth / 2 ul ) - 240
oXr = 0
oYr = 90
oZr = 0
oRotateOrder = "X,Y,Z"
If B1C = None Then
	GoTo B2C1
Else oWhere = "B1C2"
'[ Place component
Start:
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oOccurrence As ComponentOccurrence
'placement co-ordinates in mm's
oOccurrence = oAsmCompDef.Occurrences.Add(oPath, CreateMatrixRotate(oX, oY, oZ, _
	oXr, oYr, oZr, oRotateOrder))
oOccurrence.Grounded = True
'zoom all
ThisApplication.ActiveView.Fit
End Sub
Function CreateMatrixRotate(X As Double, Y As Double, Z As Double, _
	XAngleDeg As Double, YAngleDeg As Double, ZAngleDeg As Double, oRotateOrder As String) As Matrix
	Dim XAngle As Double = XAngleDeg * (Math.PI / 180)
	Dim YAngle As Double = YAngleDeg * (Math.PI / 180)
	Dim ZAngle As Double = ZAngleDeg * (Math.PI / 180)
	Dim oTg As Inventor.TransientGeometry = ThisApplication.TransientGeometry
	Dim oMatrix As Matrix = oTg.CreateMatrix
	'ROTATE MATRIX
	Dim oFirstAxis As String = oRotateOrder.Split(",")(0)
	Dim oSecondAxis As String = oRotateOrder.Split(",")(1)
	Dim oThirdAxis As String = oRotateOrder.Split(",")(2)
	If oFirstAxis = "X"
		RotateAroundX(oMatrix, XAngle)
	ElseIf oFirstAxis = "Y"
		RotateAroundY(oMatrix, YAngle)
	ElseIf oFirstAxis = "Z"
		RotateAroundZ(oMatrix, ZAngle)
	If oSecondAxis = "X"
	ElseIf oSecondAxis = "Y"
	ElseIf oSecondAxis = "Z"
	If oThirdAxis = "X"
	ElseIf oThirdAxis = "Y"
	ElseIf oThirdAxis = "Z"
	'Translate Matrix
	Dim oTranslateVector As Vector = oTg.CreateVector(X/10,Y/10,Z/10)
	oMatrix.SetTranslation(oTranslateVector, False)
	Return oMatrix
End Function
Sub RotateAroundX(oMatrix As Matrix, rotationAngle As Double)
Dim oRotateMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
		oRotateMatrix.Cell(1, 1) = 1
		oRotateMatrix.Cell(1, 2) = 0
		oRotateMatrix.Cell(1, 3) = 0
		oRotateMatrix.Cell(2, 1) = 0
		oRotateMatrix.Cell(2, 2) = Math.Cos(rotationAngle)
		oRotateMatrix.Cell(2, 3) = - Math.Sin(rotationAngle)
		oRotateMatrix.Cell(3, 1) = 0
		oRotateMatrix.Cell(3, 2) = Math.Sin(rotationAngle)
		oRotateMatrix.Cell(3, 3) = Math.Cos(rotationAngle)
		oMatrix.TransformBy(oRotateMatrix)
End Sub
Sub RotateAroundY(oMatrix As Matrix, rotationAngle As Double)
		oRotateMatrix.Cell(1, 1) = Math.Cos(rotationAngle)
		oRotateMatrix.Cell(1, 3) = Math.Sin(rotationAngle)
		oRotateMatrix.Cell(2, 2) = 1
		oRotateMatrix.Cell(2, 3) = 0
		oRotateMatrix.Cell(3, 1) = - Math.Sin(rotationAngle)
		oRotateMatrix.Cell(3, 2) = 0
End Sub
Sub RotateAroundZ(oMatrix As Inventor.Matrix, rotationAngle As Double)
		oRotateMatrix.Cell(1, 2) = - Math.Sin(rotationAngle)
		oRotateMatrix.Cell(2, 1) = Math.Sin(rotationAngle)
		oRotateMatrix.Cell(3, 3) = 1
GoTo oWhere
End Sub
End Class
'Place second cabinet
B1C2:
oZ = -( RobotFrameDepth / 2 ul ) - 240
oYr = - 90
oWhere = "B2C1"
GoTo Start
B2C1:
etc etc
JhoelForshav
Hi @SharkDesign
Your label has to be in the same sub as the GoTo-statement.
In the code you posted now your label isn't even in the class nor a sub...
I dont think using GoTo is your best option here. GoTo is almost never the best option IMO 🙂
What i suggest you do is this:
Dim your variables with initial values when the class is instantiated.
Put your different If-statements that determains how the variables should be set and have them call subs setting the variables.
If the code should run from the top, simply call the main sub from within by Main().
This has to be in an If-statement because if it always runs Main from within Main you'll get stuck in an infinity loop.
Here's a very simple example on how to call Main from within itself:
Class ThisRule
	Dim i As Integer = 1
	Sub Main
		MsgBox(i)
		i += 1
		If i <= 8
			Main()
	End Sub
End Class
