Using an assembly with iLogic and Form as a sub-assembly and be able to update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created an assembly of a threshold for a door that has both ilogic rules and a form where the user can input door frame width and the model will adjust to the proper configuration. I now would like to use this assembly as a sub-assembly where I can add the remaining components, like door frame, hinges and ultimately another sub-assembly of a door and all its components. The problem I have is I'm not sure how to make this happen. I would like to be able to create a form in the new assembly that will answer the same questions that are part of the threshold sub-assembly. I have searched through the forum and internet and have not been able to find a solution. Any ideas would be greatly appreciated. I have attached a picture of the model of the threshold and the form that gets filled out. The ultimate goal is to have a complete door assembly where I can swap out thresholds in-sweep and out-sweep along with other sub-assemblies like door configurations. Thanks,
