User input
mk92
User input
mk92
we have an Part with 4 Parameter, lets call them A,B,C,D they are depending on each other in their formulas.
If A changes, the other three have to be new calculated.
I got this working, but i think in an unelegant way. I use a Parameter like A-Memory as help and i say:
If A <> A-Memory then
B = ...
C...
D..
End if
And the same for B,C,D. Is there a better way?
Now the Point where i dont know any solution except a huge ton of If else chains.
If A and B Change at the same time (which is possible in the Factory Design Suite) the other 2 are new calculated and A,B are fix.
Any ideas?
Kind regards
Owner2229
Hi, it would be nice to see the equations for these to fully understand your request, but here's what comes on my mind:
You can create 4 rules, each starting with:
s = A 'or B or C or D
The "s = A" then serves as a trigger when the parameter "A" changes.
Below this you can write your equations, e.g.:
s = A
B = A * 2
C = B * 3
D = A + 4
Don't wrap it in "Parameter("d0"). E.g. for the parameter called "d0" it will be:
s = d0
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
