Use same Prompted Entry twice
evettem
evettem
Is there a way to use the same "Promted Entry" more than once in the same Title Block?
In my case the drawing number is required at two instances in the same title block.
I know in Autocad it is required to create a field, but can't find the same options in Inventor 2018.
chandra.shekar.g
Autodesk Support
Autodesk Support
@evettem,
Try the suggestions provided in the following blog links
https://synergiscadblog.com/2015/02/17/fill-out-your-title-block-with-an-ilogic-form/
https://synergiscadblog.com/2015/03/10/doing-more-with-your-title-block-ilogic-form-part-2/
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
