Hi everyone
I have a question propose, I would like replace text of existing Leader Note with a new text through ilogic , but the code does not work, can someone help me find the error.
I want replace "P9" in "N9"
code :
If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
MessageBox.Show("This rule only works in a drawing document.", "Change Leader Text",MessageBoxButtons.OK,MessageBoxIcon.Error)
Return
End If
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oLeaderNote As LeaderNote
Dim TXT2Find As String
Dim NewTXT As String
saveOriginalText = False
addDescription = False
Question = MessageBox.Show("Overwrite existing leader text?", "Change Leader Text",MessageBoxButtons.YesNoCancel,MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
Select Case Question:
Case vbYes
Case vbNo
saveOriginalText = True
Case vbCancel
Return
End Select
oDescription = NewTXT
'get user input
TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
'look for blank value
If TXT2Find ="" Then
Return 'exit rule
Else
'Continue rule
End If
NewTXT = InputBox("Enter Text To Replace '"& TXT2Find _
& "' with.", "iLogic", "****")
oSheets = oDoc.Sheets
For Each oSheet In oSheets
Try
oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
'look at gerenal notes
For Each oGeneralNote In oGeneralNotes
If oGeneralNote.FormattedText = TXT2Find Then
oGeneralNote.FormattedText = NewTXT
Else
End If
Next
Catch
oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
For Each oLeaderNote In oLeaderNotes
If oLeaderNote.FormattedText = TXT2Find Then
oLeaderNote.FormattedText = NewTXT
Else
End If
Next
End Try
Next
For Each oLeaderNote In oDoc.ActiveSheet.DrawingNotes
'saves the original text
originalText = oLeaderNote.FormattedText
oLeaderNote.FormattedText = oDescription
'adds original beginning to end of label text if applicable
If saveOriginalText = True Then
oLeaderNote.FormattedText = oLeaderNote.FormattedText & vbCr & originalText
End If
Next
Hi everyone
code :
Return
End If
Case vbYes
Case vbNo
Case vbCancel
Return
End Select
'get user input
Return 'exit rule
Else
'Continue rule
End If
Try
Else
End If
Next
Catch
Else
End If
Next
End Try
Next
End If
Next
Solved by JhoelForshav. Go to Solution.
Are you familiar with formatted text? They can get complicated, because they use XML tags within, to represent linked/live iProperties & parameters. You may want to replace the regular text instead of the formatted text.
Here is an example code using the regular text.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim saveOriginalText As Boolean = False
Dim addDescription As Boolean = False
Question = MsgBox("Overwrite existing leader text?",vbYesNoCancel + vbQuestion + vbDefaultButton1, "Change Leader Text")
Case vbYes
Case vbNo
Case vbCancel
Return
End Select
Dim TXT2Find As String = InputBox("Enter Text To Find:", "iLogic")
If TXT2Find = "" Then
MsgBox("Text to find was blank, so exiting.",vbOKOnly," ")
Return
End If
Dim NewTXT As String = InputBox("Enter Text To Replace '" & TXT2Find & "' with.", "iLogic")
If oNewTXT = "" Then
MsgBox("Text to replace original was blank, so exiting.", vbOKOnly, " ")
Return
End If
Dim oLNotes As LeaderNotes
Dim oLNote As LeaderNote
For Each oSheet As Sheet In oDDoc.Sheets
oLNotes = oSheet.DrawingNotes.LeaderNotes
For Each oLNote In oLNotes
If oLNote.Text = TXT2Find Then
oLNote.Text = NewTXT & vbCrLf & oLNote.Text
Else
End If
End If
Next
Next
Wesley Crihfield
(Not an Autodesk Employee)
Return
End If
Case vbYes
Case vbNo
Case vbCancel
Return
End Select
Return
End If
Return
End If
Else
End If
End If
Next
Next
Wesley Crihfield
Thanks for your help, I don't know the formatted text. Yes changing the regular text is fine, I only have to change the content of the text. I tested your code but it doesn't work, but the message you put is nice.
Hi @omvcilindri
@WCrihfieldjust accidentially added an "o" in the parameter name NewTXT on the line:
The code works if you remove that:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE") Return End If Dim oDDoc As DrawingDocument = ThisDrawing.Document Dim saveOriginalText As Boolean = False Dim addDescription As Boolean = False Question = MsgBox("Overwrite existing leader text?",vbYesNoCancel + vbQuestion + vbDefaultButton1, "Change Leader Text") Select Case Question: Case vbYes saveOriginalText = False Case vbNo saveOriginalText = True Case vbCancel Return End Select Dim TXT2Find As String = InputBox("Enter Text To Find:", "iLogic") If TXT2Find = "" Then MsgBox("Text to find was blank, so exiting.",vbOKOnly," ") Return End If Dim NewTXT As String = InputBox("Enter Text To Replace '" & TXT2Find & "' with.", "iLogic") If NewTXT = "" Then MsgBox("Text to replace original was blank, so exiting.", vbOKOnly, " ") Return End If Dim oLNotes As LeaderNotes Dim oLNote As LeaderNote For Each oSheet As Sheet In oDDoc.Sheets oLNotes = oSheet.DrawingNotes.LeaderNotes For Each oLNote In oLNotes If oLNote.Text = TXT2Find Then If saveOriginalText = True Then oLNote.Text = NewTXT & vbCrLf & oLNote.Text Else oLNote.Text = NewTXT End If End If Next Next
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
Hi @omvcilindri
Jhoel Forshav
I also noticed that if you dont overwrite the existing text it adds a line break to the text.
This makes it a bit difficult to find that text again since you only have one row in the inputbox.
Therefore i suggest this change to the code:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE") Return End If Dim oDDoc As DrawingDocument = ThisDrawing.Document Dim saveOriginalText As Boolean = False Dim addDescription As Boolean = False Question = MsgBox("Overwrite existing leader text?",vbYesNoCancel + vbQuestion + vbDefaultButton1, "Change Leader Text") Select Case Question: Case vbYes saveOriginalText = False Case vbNo saveOriginalText = True Case vbCancel Return End Select Dim TXT2Find As String = InputBox("Enter Text To Find:", "iLogic") If TXT2Find = "" Then MsgBox("Text to find was blank, so exiting.",vbOKOnly," ") Return End If Dim NewTXT As String = InputBox("Enter Text To Replace '" & TXT2Find & "' with.", "iLogic") If NewTXT = "" Then MsgBox("Text to replace original was blank, so exiting.", vbOKOnly, " ") Return End If Dim oLNotes As LeaderNotes Dim oLNote As LeaderNote For Each oSheet As Sheet In oDDoc.Sheets oLNotes = oSheet.DrawingNotes.LeaderNotes For Each oLNote In oLNotes Dim oTxt As String = oLNote.Text If oTxt.Contains(Chr(10)) Then oTxt = oTxt.Replace(Chr(10), " ") If oTxt = TXT2Find Then If saveOriginalText = True Then oLNote.Text = NewTXT & vbCrLf & oLNote.Text Else oLNote.Text = NewTXT End If End If Next Next
It'll find the text even if there's a line break in it if you just use a simple blank space in the inputbox 🙂
Jhoel Forshav
Jhoel Forshav
nice job congratulations
I am constantly amazed at your abilities. Looking at your work, it seems that nothing is impossible for you 👍 👍👍
Hi @JhoelForshav ,
Would you able to help me in something similar? I have callouts already showing some Iproperties. I need to add more Iproperties and custom properties to some of these callouts. Is any way to run and Irule to select only the callouts I need to add the information and do it automatically. Something similar to the "Match Properties" in AutoCAD.
Daniel V.
Hi @JhoelForshav ,
Daniel V.
So I came across this attempting to do something similar. I have a bunch of drawings where I need to change the leader text to the proper acronyms. So SHT needs to change to SH to comply w/ the ASME convention. I'm using VB so I can better troubleshoot. The code seems to work but where ever there's a break (meaning text in 2 rows on top of eachother) the code overwrites that to be one line. How do I correct this so the format remains the same?
Private Sub Replace_Text_Click(sender As Object, e As EventArgs) Handles Replace_Text.Click
If appApp.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This rule only works for Drawing Documents.", vbOKOnly, "WRONG DOCUMENT TYPE")
Return
End If
Dim oDDoc As DrawingDocument = appApp.ActiveDocument
'Question = MsgBox("Overwrite existing leader text?",vbYesNoCancel + vbQuestion + vbDefaultButton1, "Change Leader Text")
'Select Case Question:
'Case vbYes
' saveOriginalText = False
'Case vbNo
' saveOriginalText = True
'Case vbCancel
' Return
'End Select
MsgBox("Text to find was blank, so exiting.", vbOKOnly, " ")
Return
End If
If NewTXT = "" Then
Return
End If
If oTxt.Contains(TXT2Find) Then
oTxt = oTxt.Replace(TXT2Find, NewTXT)
appApp.ScreenUpdating = True
End If
' Do Nothing
End If
Next
Next
End Sub
Return
End If
'Case vbYes
'Case vbNo
'Case vbCancel
' Return
'End Select
Return
End If
If NewTXT = "" Then
Return
End If
End If
' Do Nothing
End If
Next
Next
End Sub
