Use GoExcel without Excel Application
MESZ.CIDEON
MESZ.CIDEON
is it possible to use iLogic GoExcel functionalities without using the Excel Application in the Background? I've got some Problems with Inventor 2020 and Excel 2019. The Performance is really bad in this scenario and without Excel on a Client or Excel 2016, it's much faster and don't throw errors.
Thank you!
Best regards, Mike Schmitz.
WCrihfield
Hi @MESZ.CIDEON.  This has been a fairly common issue in the past.  They introduced new functionality for how Inventor interacts with (or without) Excel in Inventor 2021 (and newer), but there were a couple common things folks did before that.  Here are some links on the subject:
Embedded excel sheet not supported on this platform
Autodesk Inventor: Long waiting time when working with threads and holes
Inventor files are too large and take a long time to open
Inventor 2018 Performance on Windows 10 when assembly has linked spreadsheet.
Error "excel not registered" is received when trying to create a hole with Inventor 2016
Thread operations do not work in Inventor after installing Microsoft security updates - KB4041681 (W...
You will notice one thing in common in each of these cases...they are all recommended to use the UseLibXL system variable.  I don't know if this will help in your case or not, but it might.
Wesley Crihfield
(Not an Autodesk Employee)
MESZ.CIDEON
Thank you for your Support. The solution was to set the UseLibXL environment variable to true. No Full Excel will be use for GoExcel.
